Отремонтируйте ваше устройство
Обучение ремонту
Магазин
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
237вопросов Показать все
Do I necessarily need to re-calibrate my fans?
So, I have a dual 2.0GHz G5. The logic board died, so I'm looking to replace it. I've found one that has the same specs exactly.
So here's the big question: If I do a swap like this, will I need to re-calibrate the fans? Or will they remember what they were running at before and be okay?
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
Оценка 0
Комментарии:
As a side note, I called Apple about possibly coming in to get the fans calibrated. They denied my request due to the "age of the machine". This may or may not be true of other stores, but it's definitely worth calling ahead in advance.
из
Добавить комментарий
1 ответ
Выбранное решение
Your fans will go screaming off into the night without calibration. You will need either the original installation disk or ASD 2.5.8 to calibrate the fans.
Был ли этот ответ полезен?
Оценка 2
Комментарии:
A buddy of mine has the 2.5.7 version... would that work, or do I absolutely need 2.5.8?
из
Добавьте свой ответ
Josh Calvetti будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 2,735
