The Microsoft Surface Pro 2 is a Tablet/Laptop fusion that was released in 2013. The Surface Pro 2 is the successor of Microsoft's Surface Pro and uses Windows 8.1 through Windows 10.
40вопросов Показать все
want to have same win 8.1 but on a larger HD
how to clone the old HD and then replace it with a larger one. want all the current things on my hd on the new one exactly.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You simply need to clone your old drive to the new one. I have done this many times. Because I do it often I use paid software, but there is Freeware out there that will do the job. (Note: I have never used it.) You will find one example at this link:
http://www.disk-partition.com/windows-8/...
If any questions, just ask.
Good luck,
Russ
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
hosea mcclain будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 41
