Not didating the hard drive
i removed the cmos battery from the mother board after fixing it back, when i tried to on it, i discovered that the system is no longer dictating the hard drive, so in this case, what do i do?
Это хороший вопрос?
Это хороший вопрос?
Boot to the BIOS, by Tapping the F2 key when you Power On. When the BIOS screen come up, scroll to the "Disk #1" setting and press Enter. It should find your hard drive. Save and Exit, and your drive should now be the default.
Good luck,
Russ
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 144
2 Комментариев
tanx so much, but i have done that sir, but the issue here is that, the system is not entering BIOS setup, i have been using my F2 command but it has refused to enter setup, is still showing operating system not found, so what do i do next
из onyebuchiadieze
Remove the computer battery and the CMOS battery for 30 minutes, then replace both and try again to enter Setup.
из Russ Walden
