Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179вопросов Показать все
How to fix Hyperflashing LED Turn Signals?
I recently installed LED rear turn signal bulbs onto my 05 Grand Caravan SXT, I want to know a good way to stop the hyperflashing that happens.
Is replacing the fuse with a higher amp my best bet when it comes to this? I don't want to spend too much on this. If this is my best bet what is the fuse/ relay called?
Thank you.
Lights I used
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
No, you need to install a resistor in parallel with the led globe, as the current draw if the Led is not enought to operate the flasher relais properly.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Scott будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 511
