after lcd and digitizer replacement, home button no worky
Home button was working fine before the repair, even with a severely shattered screen. New ifixit parts went in nice and smooth, everything work now except the home buttons. My digitizer and lcd cables are fully seated (no white lines) and locked down. Any ideas guys? Bad home button on new digitizer.
Это хороший вопрос?
2 Комментариев
Is there a way to electrically test the circuit that simulates what happens when the home button is pushed (i.e causing continuity between the two gold posts on the dock connector. By shorting out the two gold posts in the dock connector that should simulate pushing the home button (which does just that). If I short the gold posts together and dont get any home button "response", am I then to assume that my dock connector ribbon cable assy is faulty?
из john Scrivener
You can test the home button on the digitizer glass by using a multimeter and checking for contenuity while pressing the home button down.
You can also take the home button from the digitizer assembly and place it on the two connection points on the charging assembly and see if it responds there.
If you can't get it to work at all then the home button is faulty.
из Ben
