Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Touch ID doesn't work after screen replacement
I recently did a screen replacement full with digitizer, sadly after doing this the touch ID in my iPhone is no longer functional, im using the same motherboard that came with the iPhone so it should be working. The home button does work, I restore the phone, and even changed from digitizer but nothing seems to work. Please someone help me I love Touch ID.
Это хороший вопрос?
Оценка 0
1 Комментарий
both the digitizer and home button dont seem damaged at all, but maybe im just looking incorrectly, is there a way to know? Please help.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I'm replying assuming it still works as a home button, clicks and takes you out of an app and back to the home screen, etc. I am also assuming you have double checked your connections, sometimes it's just a pin alignment issue and just need to be unplugged and plugged back in. If you have tried all of those things and still no luck, sometimes TouchID can be affected if you damage the long flex cable that runs along the metal plate behind the screen, connecting the home button and board. Have you checked it for any nicks or tears? If there is any damage whatsoever, you may need to replace that. Hopefully that is your issue, as it is a simple fix. :)
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Marcelo Marquez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 98
