click wheel change but still not working
hello guys i change click wheel today i pod video 60gb but still not working i have to change the motherboard or i cant fix that thanks.
Это хороший вопрос?
Это хороший вопрос?
You can try to accomplish anyone of those two steps below, but it might be difficult if your click wheel is not responding. Double check your connections and make sure that your wheel is properly connected and that the clip that holds the cable in the connector is closed. Not knowing why you replace the wheel makes it a little bit more difficult to determine the actual cause. If you have a new wheel, as well as all connections are made, and you can not restore or reset I would think that the error is on your logic board.To reset an iPod Fifth Generation (iPod Video):
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
http://www.reset-ipod.com/reset-ipod-vid...
How to restore your Fifth Generation iPod (iPod with video)
1. Make sure you’ve installed the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the Source pane in iTunes.
4. Select your iPod in the Source pane and you will see information about it appear in the Summary tab of the main iTunes window.
5. Click the Restore button. A window will appear asking "Are you sure you want to restore the iPod "iPod" to its factory settings? All of your songs and other data will be erased."
6. Click Restore again. (If you're on a Mac, you'll then need to type in your password.)
7. During stage 1 of the restore, a progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.http://support.apple.com/kb/HT2613?viewl...
Был ли этот ответ полезен?
If the clickwheel isn't responsive... it's typically the motherboard. I've only replaced 2 clickwheels in my professional experience. Every other time, it was the motherboard. Sorry.
Agreed, I believe if you replace the click wheel and it is still unresponsive the problem is with the board. I replace my clickwheel and it was 100% for about 2 minutes before becoming unresponsive. I found this very strange because I booted the ipod into diagnostic mode and it did pass auto diagnostic just fine, however manual diagnostic yielded no responses from the click wheel.
I was really upset but let's be honest these Ipod's are now legacy devices and a majority of them are very fragile. I'm repairing/upgrading mine as more of a bookshelf jukebox rather than an active/mobile mp3 player.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,237
1 Комментарий
milton, my number one question would be why did you change the click wheel? what happened to the iPod that you changed the wheel?
из oldturkey03
