Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98вопросов Показать все
Leaks water when brewing ground coffee with a My K-Cup filter.
I own a Keurig Elite. My parents have a Keurig Special, and both have this problem. When I use the My K-Cup filter to add my own ground coffee and brew it, after it starts pouring out coffee, the machine starts leaking water at the same time, so typically the mug beneath the machine is filled partly with coffee and partly with hot water, so it gets very watered down. I think this comes from a design flaw, but it would be great if there is a way to fix this problem so that the My K-Cup filter will work as it is supposed to.
Does anyone know how to fix this?
Это хороший вопрос?
Оценка 4
8 Комментариев
Click this link. It will take you to ebay and a new part that fixes My K-Cup leaks and other reusable K-Cups like Ekobrew Solofill Cafe Cup and EZ Cup. It's only $2.79 and guaranteed by money back and return postage paid.
http://www.ebay.com/itm/EASY-FIX-STOP-CO...
из
If you use Cafe Cup brand cups, there is a removable fitment in the lid that has the needle opening in it (half sphere perforated basket below it). If the fitment is missing causes leaking and there is no way to fix it except replace the fitment or entire cup if lost like mine was. For other cups I found a washer behind the needle seal did the trick.
из
CORRECTION TO ABOVE "Click this link. It will take you to ebay . . . ".
https://www.ebay.com/itm/171557357690
The previous link was inadvertently deleted. This one works. Sorry about that.
из
Good link, but the price is now $4.95
из
Hi suzshark
Yes, costs and prices to sell and ship the "stop k-cup leaks" part has gone up a lot since January 2015 when the retail price was $2.79. But hopefully the fix will work for you so your results will be well worth the price. And if you don't get good results, you can return the part for a full refund including return postage.
из
Показать 3 больше комментариев
Добавить комментарий
12 Ответов
Наиболее полезный ответ
I saw this fix on Youtube awhile back...wrap a rubber band around the reusable cup filter, just under the lip - below where it opens and closes. It makes a great seal and works! The rubber band can stay on the cup all the time, you just operate like usual (fill the container with coffee, brew, clean) and forget the rubber band is there. I've had it on for a year and it still is holding up just fine. I've also tried a 1/2 inch washer that goes on the top of the reusable coffee container. Both solutions will work just fine on their own, but I kept losing the washer or forgetting to put it on when I brewed. The rubber band worked better only because I didn't have to keep track of a loose part (the washer).
Был ли этот ответ полезен?
Оценка 6
3 Комментариев:
Rubberband fix was genious!!! It works beautifully! No more coffee and/or water spurting out all over the place! No more having to stand and place pressure on the handle while the coffee brews. Thank you! Thank you! Thank you!
из
Tippy or song bird, could you please show me the link? This what I have. https://www.kitchenstuffplus.com/as-seen...
из
I put a hair tie on mine and hoping it will hold up. Do I hard to use a rubber band or can I use a hair tie?
из
I too struggled with the same problem. I have tried the K-Kaps with varying success as they also tend to leak.
Below is what I now do. It sounds like a lot, but it really takes very little time. I read once that K-Cup coffee costs about $50 a pound if you figured it out. Yikes!! Not sure about that, but I'm a single dad with two kids in University and I really needed to trim a bit off of my budget. This was an area that could help.
What has worked best for me, is re-using the plastic K-Cups. After brewing, remove the K-Cup, let it cool, peel off the foil, then rinse it out and dry throughly.
When I want a coffee, I just grab one of my used, dry K-Cups add my favourite coffee. I cut a bunch of small foil squares ahead of time and I simple re-seal the K-Cup with a new foil top, crimping the foil highly around the edges. I have NEVER had a leak, it works wonderfully.
Some argue that this defeats the convenience factor of the Keurig machine and I can't disagree, it does add a little extra work. At the end of the day, I needed to save a little money and re-using each K-cup 4 or 5 times really saves money. If I am pushed for time, I use a new K-Cup, but most days, I use a used one.
Оценка 3
3 Комментариев:
I just tried your method and it works perfectly! Really didn't take much time at all. Thanks for sharing!
из
I don't know but this is a suggestion. For the foil use a stamping up circle the right size, or one from Joanne's fabric store. The foil will keep the circle cutter sharp too. I hope this helps with your time cutting foil issue.
из
I found a rubber washer that fits in the round space on top of the reusable k cup filter. It works great.
из
We have the same at work and we've been told by the seller that they sometimes come with that rubber ring that is needed sometimes they don't. Our rubber ring goes around the metal needle on the top part of the machine (the needle that usually puncture the regular K-Cup)
i've seen other types fitting on top of the grey adapter's cover.
once you have this, no more spills!
Cheers!
Оценка 1
SOLVED !
Just carefully slide the rubber gasket off of the needle on top... add a few small washers and replace the rubber gasket...this will seal the k-up and no more leaks... works great!
RAVEN @¿@
Оценка 1
The easy fix is still on ebay for $4.95. It's a new part that goes into the lid and takes literally one minute to install in the brewer. Then you never see it or touch it again. And best of all you don't have to remove it to brew retail K-cups you buy at the store. And if you aren't satisfied you get your money refunded and return postage paid.
Оценка 1
3 Комментариев:
I went to check the item on eBay as suggested. Posed a question to the seller, who was very shady, disrespectful and belittling. Assumed right off the bat I was going to leave negative feedback. The seller is very confrontational. Check out the negative reviews the seller has received....unfortunately, they are all true. She calls someone a 'Weasel' who left her negative feedback and then left another comment for someone else stating the buyer 'has balls'.
I did receive a positive response from a different seller...aviatorpilot21. The product he offers appears to stop the leaks as well. The item is: http://www.ebay.com/itm/401083377744?eui...
Don't believe me? Contact the ebay seller: long2putt via Ebay and you are more than likely to receive a nasty remark regarding his/her product: http://www.ebay.com/itm/EASY-FIX-STOP-CO...
из
Be Advised: Perro Caliente is a phony name as is the comment above. It's a prank. "Perro Caliente" is a Spanish term. Translated to English is "Hot Dog" From the sound of the comment above it appears to be a ploy to swing sales to that other ebay seller with a similar product.
из
I used the rubber band trick. Cost me $0, no shipping, no waiting, had one in my kitchen drawer. Worked like a charm.
из
I'm looking into getting one of the "My K-Cup" filters but I could see the design flaw. There is filter material on the side of the filter, where the water could simply flow over the coffee, and go right down the sides. Larger coffee makers don't have this sort of problem because the filter is so large, and the water is deposited directly in the middle of the grounds. Solution: Block off the sides of the filter. There might be problems like the water won't flow fast enough and will overflow, but thats a risk you take. There are also a few alternatives to the My K-Cup you might want to look into.
Оценка 0
I was having this problem and it was frustrating, to say the least. I found that the problem with the My K-Cup leaking and producing a short cup of coffee was the brand of coffee that I bought. On two different occasions, I bought a store-brand coffee and Folgers Custom Roast and had the problem. When I went out and bought Maxwell House Master Blend, the problem was alleviated. It must have something to do with the fineness of the grind. I'm sure there are other brands out there that would give good results, but my experience is, so far, with the Maxwell House Coffee. Also, if I fill the filter to the very top, I would have the problem, so I now fill the filter to 1/4" from the top. It took me awhile to figure it out but I no longer have the problem
Оценка 0
I had a problem using refillable K-cups. I have several refill cups so I can have more than one cup of coffee before I need to clean the refill cups. Sometimes the Keurig would spray water and coffee all over and only partially fill the cup. After reading about the washers on the needle inspected my Keurig and the refill cups. One of the refill cups lost the gasket on top that kept the coffee from spilling over. I threw away the broken refill cup and my problem is solved.
Оценка 0
I have been using reusable cafe` cups and found that the plastic ring popped out on top resulting in water leaking from the k cup chamber. I found the ring, placed it back on top and Problem solved!
Оценка 0
Replace the reusable k-cups. Problem solved
Оценка 0
Thank you thank you thank you all!
These reusable pods have been driving me nuts for too long. Water would back up at the top dumping grounds into my cup. Tried three of these suggestions and all worked. Ended up inserting a couple washers under the top gasket. NO MORE GROUNDS IN MY CUP!!
Оценка 0
2 Комментариев:
Thank you Joe. It works!
из
Great news Joe, Tell the readers where to get the correct washers:
из
PROBLEM SOLVED! There is a permanent fix available on ebay that works like a charm. It’s a small part that you add inside the lid of the brewer in seconds without tools. It works instantly to pour your coffee perfectly again. And it’s guaranteed. Paste this link: https://www.ebay.com/itm/171557357690
Оценка 0
Добавьте свой ответ
Andrew будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 173
За последние 30 дней: 681
За всё время: 103,545
