This is WEIRD!
I installed a fresh clean MacOS High Sierra on my MBA 2015. Worked fine.
I then turned the mac off and left it for about a month.
I came back to it just the other day, and it won't turn on.
Plugged in charger - green light at first, then red light.
Ok, I thought it'll charge a bit and turn on (even though I do remember turning the mac off before I left for my break).
Came back after 30 minutes. Still won't turn on.
Thought it was the charger. Plugged in another charger (which works for sure). Same thing.
Weird.
Did all the reset BS that I found online (SMC, SM-this, SM-that, PM, PR, all that stuff). Nothing.
Opened it up for inspection. Looks like it's brand new (seriously - I take care of my stuff like crazy! A bit OCD on these things).
Disconnected battery and reconnected it. NOTHING.
What gives?
Anyone here has a clue?
Here are some pics:
https://imgur.com/uLsVAtI
https://imgur.com/Bq8cob3
https://imgur.com/G3A3BVf
https://imgur.com/a/MEAYUBB
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
9 Комментариев
Hi! I'm having the very same issue with the exact same model - MBP A1502 (13" Retina).
It won't power up and the charger is amber EVEN with the battery removed. Does anyone have an update on the probable cause because it's a fascinating new feature I have never seen before and by the looks of it, it only affects the 1502
из Tim
Same issue too and model
из Blake Joynes
I have the same issue right now and I have no clue what to do… If anyone has more recent information I would love a way to fix this
из Benjamin Sheffield
I have a MacBook Air 2017 13inch it have the same issue
из Alot More Tech
You all have logic board issues! You'll need to either find someone with the needed skills and tools to repair your logic board or just replace it.
из Dan
Показать 4 больше комментариев
