Released March 2016, 7.0" Galaxy Tablet by Samsung.
36вопросов Показать все
there is a X mark on battery icon
I dont know if its the charger or the pin in the tablet that has something wrong. When i plug the charger there is a red X mark on the battery and it wont charge. I have to power off the device in order to charge it but I need to stay the evice open because i need things in here. Help how do i fix it?
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
If you are charging it via your computer, switch to a charger.
Был ли этот ответ полезен?
Оценка 3
Комментарии:
No, im charging it with its charger. But there still an X mark
из
Usually this means battery is bad or near end lift. Try to use the device till battery is completely drained then full charge again. Repeat this step for 2 to 3 times and if it still happen. You need a new battery.
Оценка 0
Добавьте свой ответ
aju shee будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 21
За последние 7 дней: 120
За последние 30 дней: 470
За всё время: 7,567
