The X5 Max Pro is a low-end slate Android smartphone released by Doogee in June 2016. This device has no readily available model number.
Ghost touch while playing MOBA games (Mobile Legends)
While I am playing Mobile Legends, I experience ghost touch in which I the touch point is bit far from from where I am touching. I played different MOBA games and the same issue I experience. Any help is accepted.
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Umm I also play mobile Legends but you can go and you will see a gamemode you recently played ,the chests, events and the shop then you will see at the top a person with headphones press it and you type your problem and then the person will help you.
Был ли этот ответ полезен?
Счет 0
Try replacing the digitizer.
Счет 0
Cara memakai cit gimana
Счет 0
Добавьте свой ответ
Elmer Fang буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 581
