Where is the pixel wifi antenna?
my pixel fell onto ground and since then the wifi becomes very weak. wifi can be found but not connected unless i put the phone on the wifi router. maybe some problems are within the wifi antenna. i tear the pixel down but cannot find the wifi antenna. can anyone show me the position? really need help
Это хороший вопрос?
5 Комментариев
I am also facing same problem. Can you please tell me how did you fix your connectivity issue?
из Marmik Shrestha
@tosepe could you fix the problem? I have the exact same issue after i dropped it. It would be very helpful if you share what happened
из Seenat
How was the problem fixed? Was anyone able to solve it?
из amadib
i have also the same issue with my pixel
из SaLlar KhAn
My speeds on my pixle 3 XL is 15mb with data and Wi-Fi compare it to my Samsung note 4 and my note 4 is getting more than double of the speed my pixel 3 is supposed to get
из Callum Bhayani
