An Android smartphone identifiable by the model number d2004 or d2005, released in March 2014.
13вопросов Показать все
Phone is locked and I cant find any way to recover my phone
There was this phone that I found, and it worked, but it had a pattern password that I never could open. Since it is an old phone, I never knew what Android version it was using. However, I did a test to see if the OS was under Android 4.4 by entering an incorrect password five times. It did not give me any screens that allowed me to use a Google password or a backup password, so it leads me to believe that it is running Android 5.0 and up, which means that it may have a Google account on it, which, again, I don't know the password to.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi!
You could try to enter the recovery mode and do a reset of the phone:
  1. Turn your device off.
  2. At the same time, press the Power button and Volume down until your device vibrates.
  3. Quickly release the Power button, but keep pressing Volume down, you will know when to stop if it goes well. To navigate through the recovery mode options, you typically use the Volume up and Volume down keys, and then the Power key to make a selection. Now navigate the menu and look for a reset option.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
KURT C будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 870
