MacBook Pro Randomly shuts off
MacBook Pro 13" 7.1 mid 2010 2.4ghz
Put a brand new SSD in it, OS X sierra, reset prams, sds and still shuts off. Took it to apple and they said it was the battery, I know that the battery needs to be replaced and the Apple Store told me that I could take out the battery and just run the computer without the battery so I tried it and it still randomly shuts off with just AC power. Please help!!!!
Update
I will try to download coconut battery but not sure if I will have time to before it shuts off.
The fan has no dust I already blow it it and when the computer starts up the fan turns on but the computer shuts off before it would have a chance to get hot.
I will open it up tonight and take a look at the fan again and try and download the coconut battery.
Thanks,
Chad
Update (08/30/2017)
Update guys!!! I broke down and took everything apart and blow/cleaned it out found a huge dust bunny in the fan/heat sink and I replaced the thermal paste ( FYI the old stuff was so dried out it was like chalk). I think it was the thermal paste cause I have had it playing videos for the last hour and it hasn't turned off so I believe for now it is fixed!!!!
Это хороший вопрос?
2 Комментариев
Did the answer that you accepted solve your problem? If not, you need to un-accept it because questions with an accepted answer are not looked at anymore as the problem is assumed to be solved.
из mayer
So bad news it is still doing it!! Not sure where to go now. Keyboard/on/off button? Need help again!!
из Chad chesley
