The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
501вопросов Показать все
My Kenmore washer won't spin.
It fills up with water n then it does to spin cycle. It sounds like it's spinning but the middle piece inside don't spin at all so when it drains it don't drain all the water out.
Это хороший вопрос?
Оценка 0
3 Комментариев
I have the same problem but replaced the coupler and it still won't spin
из
@Tim Poole
What is the model number of the washer?
из
@jayeff 110.88752793, stack unit
из
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Был ли этот ответ полезен?
Оценка 1
Hi @Tim Poole
If it doesn't spin check that the clutch assembly or perhaps the clutch band is OK.
The supplier links are only to show the parts, how much they may cost and also in the case of the clutch assembly, how to replace it.
If one needs to be replaced there are other suppliers online that may suit you better. Just search for 285785 or 285790 to get results These are the manufacturer's part numbers for the clutch assembly and the clutch band, respectively.
Оценка 1
Might be the drive belt.
Kenmore 110 Series Washing Machine Drive Belt Replacement
Оценка 0
Добавьте свой ответ
Crystal Murray будет вечно благодарен.
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 15
За всё время: 10,164
