A1226 Which Improperly installed screws make open button inoperable?
I have to use 2 hands, one to push the button, and a fingernail between display and lower case to get the computer open. I read that the wrong screw length caused this, but I cannot find it referenced in any repair manual.
Update (08/31/2017)
Thanks. the problem is that when you push the button, it doesn't spring open when resting horizontally. The upper hooks release when I push the button, but it won't open without assist by a fingernail or screwdriver. If I let go of the button, it re locks closed. Are there springs that are supposed to propel it open?
Это хороший вопрос?
3 Комментариев
You have to actually READ an LOOK at the answer provided. Click on the video link.
из mayer
Ah, yes. and when I push the button to unlock the display, the properly aligned and operating hooks release. but the display doesn't move, and when I release the button it is again locked . When the person in the video pushes the button, the display pops up, not needing the prying open, So I am looking for the repair manual that takes me through the steps to the point where I can fix this. Thank you, Sir, for your patient advice.
из sdreamer9
How tight are you hinges on the back? If they are loose you might not get the proper bounce open.
из mayer
