How to adjust the carburetor
Where are the adjusting screws for the carburetor on the mower?
Это хороший вопрос?
Это хороший вопрос?
Usually removing aircleaner allows access.
If it has thumb screw at bottom of bowl,,
This is the main jet,,
Idle jet screw is small,
Inserted at side of carb,,
But now actually,,
one should pull the bowl off to
make sure no water and corrosion
Are Present,,
Using carb cleaner spray,
inserted in jet screw holes to flush out
and debris.
Counting turns in first, should give you
base where to start when back together.
Note: To protect fuel problems,
Stop at any Artic Cat parts/service centers
They have the best inline clear fuel filters.
I Add them to every power product.
Let it loop down below float bowl level,
you'll be able to see when a few drop of water stay
trapped, just blow it out,, good to go.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 469
