External Monitor
What adapter do I need to run an external monitor from a MacBook?
Это хороший вопрос?
Это хороший вопрос?
Here's the Apple page on the subject: http://support.apple.com/kb/HT1562
You need a Mini-DVI adapter. Depending on your monitor, you'll need a Mini-DVI to VGA adapter ( http://store.apple.com/us/product/M9320G... ) or a Mini-DVI to DVI adapter ( http://store.apple.com/us/product/M9321G... ).
Generally speaking, older monitors require the analog VGA connection while many (most?) newer monitors use the digital DVI connection.
If you're not sure what kind of monitor you have, here's a pretty good picture showing a VGA and a DVI plug -- the VGA is on the top. http://shop.vetcosurplus.com/catalog/ima... Check the sockets on the back of your monitor and compare the shapes to see what kind of plug you require. Some monitors have both VGA and DVI socket. In that case, I'd recommend going with the DVI adapter for better image quality.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,532
