Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Yeaaaah, I should probably replace my battery shouldn't I.
Whenever I unplug the MagSafe, it instantly shuts off. I'm assuming its due to this:
Yeah, I'm going to get a new battery lmao. I heard a Mac battery is donzo at around 300-500 cycles. This puppy is the ancestor of batteries xD
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Although that battery appears to be in poor condition, your machine should not be shutting down.
Your machine is not drawing any power from it nor does it appear to be charging.
Let's do a couple of things. Lets see if we can get it to interact better.
Disconnect the battery from the logic board and the mag-safe. Press and hold the power button for 10 seconds. Now reconnect the battery to the logic board. It should spontaneously reboot. See with Coconut battery if it doing anything.
Disconnect the mag-safe and see if it shuts down. If it does not then let the machine run on battery power until it is completely depleted. Then recharge it fully.
These measures failing, replace it with a fair good battery $60+ and we'll see if the machine will talk to the new one.
If this is the same machine you replaced the logic board on, the problem may be with the new board. Please tell us why you replaced that board, I've forgotten.
Also if you have replaced that board you may need to reset the PRAM so all the components know each other.
Press the power button and then press command-option-p-r. You have to make sure you get those keys pressed before the gray screen comes up or it won't work. Hold those keys down until your Mac reboots again and you here the startup chime.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
replied on thread: read
из
Hey mayer, I thank you. I believe that the problem was in fact correlated to the battery. I remembered that I had a spare battery from years past that was a crap knockoff ($22 on Ebay a few years ago). Although it still functions like a battery, it just doesn't hold the best charge and dies at 5% (bad battery). Anywho, it still works and causes it to stay on without the mag-safe connected. As for SMC, I reset it, and for PRAM, I did right after I installed the new board a week or two ago. I just purchased a reputable "new" battery from macsales for $100. I guess the knockoff one will have to suffice for a few days. Thank you for your concern and directions. I appreciate it mayer!
Knockoff battery coconuts:
Оценка 1
1 Комментарий:
Normal good Mac battery should last 1000-1200 cycles. Glad I could help ;-)
из
Добавьте свой ответ
Griffin Thomas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 64
