turns on but no display, also no beep but fans work
My computer turns on, but has no display through my TV. I have concluded that theTV orHDMI plug in is not the PROBLEM! I have took it apart, no dust from what Ive seen but am going in deeper later. I reseted the CMOS, using the jumper. I heard that could help but to only do that for 5-10 seconds. I may of done it for about 15-20 seconds. Did that make my problem worse and if that was the problem and I screwed up fixing it, can I do it again or is it too late? I have ordered a new CMOS battery just in case(cheap). I plan on opening it up more and trying to clean ram sticks possibly, but there wasn't any dust from what I've seen, so I don't think dust would be on the ram sticks, but will most likely still try cleaning it carefully. I have also learned to try unplugging the CMOS battery and reseting it? Or just unplug it and plug it back in? Other than that, I don't know the problem. Theres also no beep as I heard but the GPU and CPU fans work perfectly. So my only explanation is its the ram, or BIOS, with reseting the CMOS would fix right? Do I need to just unplug everything, is it the motherboard in general? What? Its a prebuilt and haven't opened it or anything until recently because of the problems, so I don't think wires are loose either?! Is it just my GPU. I planned on buying a new one around Christmas anyways... so if thats the problem FOR SURE.... its not too bad.. but still help please!
GPU- GTX 760 2GB
Это хороший вопрос?
3 Комментариев
No one answered this but if anyone sees this and has a similar question then my answer might help as my computer is now fixed.
So
1. Reset CMOS. Look up videos if needed. Possibly needing to buy a new one.
2. Clean dust in your computer, especially including RAM sticks.
3. My solution was that my computer was 100% operational, but my graphics card was a little messed up. The HDMI plug in for my GPU was messed up apparently from use. So at the moment Im using VGA until I get a new GPU in the future. This could be your problem guys.... try using VGA or getting an adapter to use VGA. VGA will work for me as of right now because all I run is 1080p, and VGA can easily run that.... so don't be scared VGA is crap...... unless your trying to run like 4k or something.
из Brett
VGA doesnt work for me what should i do then?
из Yuno
Hi @Yuno
With what. You haven't given any details.
IFIXIT does not supply mind reading services.
из mike
