The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
20вопросов Показать все
Where to get the USB-C Board or the conector to fix a ASUS Zenpad 3S
I opened up my ASUS Zenpad 3S because the USB connector is broken. It looks like the USB-pins are shoved to the back side of the plug, hence charing is impossible. So I would like to repair the connector, either by replacing the whole PCB where the USB-C female connector is sitting on, or by replacing the connector.
Does anyone have an idea where I could find the board, or how I could find out which special type of USB-C connector I need and where I can get it??
Any help is highly appreciated!
Cheers!
S
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
it looks like the zenpads take similar charge ports, you could try ebay or https://www.aliexpress.com/wholesale?cat...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
stevo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 768
