Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Won't charge, says This accessory may not be supported.
So here's the story; phone poorly taken apart, damaged chips, managed to get it to work but won't charge. One of the charging ics which I forget the name (9 pins, MOSFET, controls charging) was missing and had 3 ripped pads. Replaced that, now phones recognises charger bit says this accessory may not be supported, before would not recognise it at all. Not showing on pc at all. What should I replace next?
Это хороший вопрос?
Оценка 1
1 Комментарий
Hey Giga, I just noticed this question. If you haven't fixed this yet, please let me know which IC exactly you replaced so that I can help you out.
из
Добавить комментарий
3 Ответов
Выбранное решение
@refectio i just used the board as a donor, used almost all the parts.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Cool, at least you put it to good use.
из
1. Remove any debris from the charging port on the bottom of your device.
2. Restart your iOS device.
3. Try a different USB cable or charger.
4. Make sure that you have the latest version of iOS.
5. Contact Apple Support to set up service.
Оценка 0
3 Комментариев:
No, read the OPs original post. He took it apart and messed with the internals. It has nothing to do with a dirty charge port or bad cable/charger.
из
This is unforunately the help you get in Apple forums.... a generic stupid easy answer that doesn't answer any of your questions.
из
Apple support is always giving basic unrealistic solutions to your problem, where in the world did you need latest software to have a well charging phone?
из
I Absolutely agree John
Оценка 0
Добавьте свой ответ
Gigabit87898 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 44,084
