Is Tristar IC 1610A3 interchangeable with 610A3B?
Nice and easy question, Is 1610A3 interchangeable with 610A3B?
If it is, is it also interchangeable with 1610A1 (like it is with 1610A2 and 1610A3)
Это хороший вопрос?
Это хороший вопрос?
The 1610AX are all cross-compatible although it's preferable to use an A3 in place of the older 1610A2 & 1610A1. As for the 610A3B, it can also be used wherever an 1610AX was installed. I would not use an 1610AX in place of the 610A3B in an iPhone 7 though ( I haven't tried it personally but some have reported is does work).
Был ли этот ответ полезен?
hello guys
i have tried a2 on iphone 7 plus and it work 100%
I just tried a A3 on a IP7 and had no joy , tbh i did just dive in and change out tristar after a new port and battery didn't work and pp_bat and vcc_main read normal, will investigate more tomorrow.
I just replaced 610AB3 with a 1610A3 Works fine.This is on Ipad Pro 10.5".
Can I use 610A3B for iphone 8?
sao diferente
tou com ipad a1584, nao carrega, e ci dele e ci610a3c, sera que o ci610a3b e compativel
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 38
За всё время: 6,533
