The Voyager Edge is a Bluetooth headset from Plantronics, released in February 2014.
Why when I answer my Bluetooth the call goes to speaker phone
When i get a phone call, I answer with my voyager edge, but the call goes to my phones speaker and not thru my bluetooth
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (3)
You can install the Plantronics app "PLT Hub". That shows whether the headset has recognised that it's in your ear or not. If not, the call goes to the phone's speaker.
Sometimes it helps to place the headset on a non-metallic surface with the earpod point up while charging. This should re-calibrate the sensors.
HTH
Был ли этот ответ полезен?
Оценка 0
Check the properties of the Bluetooth connection on your phone
Settings, Bluetooth, Connected Device settings.
There should be several check boxes related to functions that the connection can be used for. (Media audio, Phone audio, etc.)
Оценка 0
I turned off the sensor and that did the trick for me.
Оценка 0
Добавьте свой ответ
Hugh Wilburn будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 2,537
