It won't turn on
It won't turn on no power at all it was working but now it's not
Это хороший вопрос?
Это хороший вопрос?
To troubleshoot this problem :
Plug something else into the same outlet. If it doesn't work, than it's a problem with that outlet.
It could also be a problem with the power chord. Make sure it's connected correctly. If you can, try to use a different one.
Check the connectors on the power chord and the outlet on the PS4 itself for sign she of damage.
If none of these work, it's probably a problem with the power supply. These are quite common, but you're probably have to take it in to a repair place.
I personally sent mine in to TronicsFix and I would highly recommend them if you decide to send it in. If not, there are various guides in the internet to replace the power supply yourself.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 208
Power from outlet?
из TCRS Circuit
Does it have bugs in it?
из TronicsFix
