Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98вопросов Показать все
Coffee dispensing by dripping
We are using a B31 Keurig single cup maker. The coffee is dripping into the cup and only dripping a little into the cup. If I do it again, it does the same thing using the original water that I put in for my cup of coffee.
Would cleaning it with vinegar help?
Barbara Scully
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
@barbscully vinegar is probably not going to help in this situation. I would suggest you clean it and check it by using this guide How to open and clean Keurig Coffee Maker
Был ли этот ответ полезен?
Оценка 0
I ran the vinegar through and it didn't clear up the problem. So, my husband took it apart and clean out the tube following the instructions you posted on the website. It worked! Now I can have my coffee.
Thanks for the website and the information on fixing the problem.
Barbara
Оценка 0
Добавьте свой ответ
Barb Scully будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 395
