Rear wobbly wheel, and rim and tyre A1
2001 Range Rover P38
Fast or slow speed, rear off side wheel wobbles ! Tyre place checked wheel and tyre, balanced it again to no avail. Refitted and still wobbles !
Это хороший вопрос?
Это хороший вопрос?
@robinvanboxel check the wheel bearing as well as the hub. Check to make sure that your half shaft assembly is not worn out or bend or has a worn bearing. You also want to check all the bushings of your Panhard rod and radius arms.
This document may help you to get started on thisRange-Rover-P38-Rear-Suspension.pdf
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 202
