Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
The tv keeps flickering when its on... Please help me
Horizontal and Diagonal Flickering lines across display....... makes the TV not easy to watch and displays no signal or data sometime ...... Does it mean i have to change something or can someone do a tear down for me pls
Это хороший вопрос?
Оценка 0
Добавить комментарий
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 ответ
Наиболее полезный ответ
@miquart2005 this will greatly depend on what make and model your TV is. This could be based on a bad t-con board, a bad panel or bad buffer boards as well as many other things. We will need more information in order to assist you. It might also help if you post some images of what your screen shows. Use this guide Adding images to an existing question for that. Let us know everything you have tried thus far to fix it. You do want to check all inputs on your TV to ensure the screen will show the same results with all inputs like HDMI, Coax, Component etc.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
michael quartey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 40
