The Moto G is Motorola's economically priced phone. It has all the features one could want in a smart phone, for half the price. Model numbers XT1032, XT1033, and XT1036.
86вопросов Показать все
Why can't I use the phone without the headphone to open any multimedia
Whenever i want to open any game the phone gets stuck. Further when i try to open any audio or video it pauses automatically. Can't seem to make calls. But when i use the phone with a headphone it works fine. Any solution to the problem would be a great help.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Добавить комментарий
1 ответ
If it works while headphones are plugged in, and rebooting hasn't fixed the problem, there's probably a physical problem in or around the headphone jack itself.
The phones I've had (Moto Droid, Moto Droid 3, Samsung Galaxy S3, iPhone 7) would all pause media playback if wired headphones became disconnected. (Come to think of it, I think my iPod Touch(es) did that too) they would not resume playback on reinsertion, probably because with media paused there was no return current on the ground.
Headphone jacks in most phones either have some form of micro-switch, or a contact that senses voltage flowing on the ground line. The purpose is to detect when you plug in headphones, and mute the internal speaker.
Wired earbud remotes generally alter the resistance of the ground return and the phone interprets different levels of resistance as different buttons.
If some form of conductive debris or corrosion is causing some unintended current to flow, that could be causing the problem.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Praveen Kumar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 57
