The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
48вопросов Показать все
Screen hinge isn’t closing all the way
When I close the laptop, the bottom right side usually tends to stay slightly open. This isn’t a huge deal, but it looks aesthetically awful. I own the 13 inch gunmetal model just in case anyone was curious.
Это хороший вопрос?
Оценка 0
4 Комментариев:
Hi, i have a razer blade 15 and i have the same problem… the lid stays open. won’t close all he way
из
same when i close it it pops back up which model do u have i have the base model and did u find a solution?
из
Having the exact same problem on my RB15 Base model. Any solutions?
из
I think the lid is being held by magnets. It must be a problem with the magnets because the frame and the lid are perfectly fine
из
Добавить комментарий
1 ответ
Have you tried opening up the bottom case to see if there are any screws for the screen hinge you can tighten up?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Would I have to open the entire bottom? If so no, I haven’t
из
I have this same problem on my stealth. It doesn’t close all the way on the left side. I heard it might b the battery but my laptop looks completely normal by the trackpad and the bottom of the laptop. Maybe it’s a magnet that’s not holding it in place. Let me know if anyone has found this fix
из
Добавьте свой ответ
AvgJoe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 2,773
