Not turning on even with fully charged battery
my laptop is didn't on what can i do? i cheak the laptop by removing battery and then i cheak the adapter, adapter is ok .
Это хороший вопрос?
Это хороший вопрос?
@dhirajg start by removing your battery, your AC adapter and your RAM. Then push and hold the power button for 30 sec. After that just install your AC adapter and see if it comes on. Try the same with your battery. If it does reinstall your memory and see if it still comes on. Failed memory module could be an issue. If it does not you will have to disassemble your computer and check the DC-jack in. Attached is the schematic for your computers power management and should help you tracking it down. You will of course need a good multimeter to check on this.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 30
За все время: 468
