Why is there gas spraying into the tube that leads to my air filter?
There is a small black hose that leads to the tube my air filter is in & the other end is on a cyndrilical metal like item...something to do with fuel I'm guessing. Gasoline comes out the end that goes into the tube that leads to my air filter, my car popped & started smoking the other day after I tried to start it, I took the air filter out, the small black hose off & plugged it up...help! What is the metal cylinder shaped item that the other end of the hose i's hooked up to called?
Thank you.
Это хороший вопрос?
1 Комментарий
@bsrigamarowe post some good pictures of what you are looking at with your question. That will allow us to see what you see. Use this guide Adding images to an existing question for that.
What exact year is it and hat engine size does it have?
из oldturkey03
