AirDrop isn't working in 10.13.x
Since upgrading to High Sierra, AirDrop hasn't worked from my iPhone 5s to my MacBook Pro 13" Mid 2012.
Does anyone know how to solve this issue?
Это хороший вопрос?
Это хороший вопрос?
Did you review this Apple T/N? Use AirDrop to send content from your Mac. Can you explain what part of the process if failing.
Был ли этот ответ полезен?
I am trying to send the photos from the iPhone to the Mac. The iPhone does not let me. The Mac lets me send them to the iPhone, but it won't receive them.
Really a great post. I have read this marvelous post. Thanks for sharing information about fix Airdrop not working Mac Sierra on MacOS. I really like that. Thanks so lot for your convene. Visit this web page: https://www.howtoisolve.com/airdrop-not-...
Im having the same issue, MacBook (13-inch, Late 2009) MacOs High Sierra version 10.13.6 (17G11023) update disabled the hyperlink to airdrop. How do I reactivate the hyperlink?
Same issue here on same MacOS
Same issue here, same OS.
same issue with my mac i dont get any options of letting anyone send me any files via airdrop. I am tired searching for a solution for the same.
I have the same issue. I’ve changes networks, upgraded, restarted, nothing helps, especially not apple. this is why we should usb ports in iPhones and iPads. I should switch.
I think this article will help you with your problem - Fix: AirDrop Not Working on iPhone 13, 13 Mini, 13 Pro & 13 Pro Max.
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 52
За всё время: 28,999
4 Комментариев
Did you also update the phones iOS?
из Dan
Are you using 10.13.0 or 10.13.1?
Also, are you using iOS 11.0.3?
из S W
I was up to date on both devices but still no joy
из P J
My iPhone 7+ will not transfer photos to my MacBook Air. The ios version on the phone is 10.13.1. The ios on the Mac is 10.13.1. What do I need to do?
из elainefarrar
