Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
155 Questions Показать все
What Are The Replacement Screws For The Switch Backplate?
Where On Earth Is This Part?
(Screws For Console Backplate, NOT JOYCONS)
So my Switch is missing 2 screws, one on the top section of the device (the screw hole near the Switch's fan hole) while one screw is missing near the bottom near the charging port. Strangely enough I do not know how these screws went missing, but I will indeed try and purchase a repalcement back for my unit, however I can never find what screws are used at all anywhere on Google, even most Ebay and Amazon serches return with suggestions of Joy-Con replacement screws,which is soemthing I do not need, I need the screws primarily for the back plate of the device. Does anyone know where to get these screws and what screws are used in the back housing of the switch? (and yes the top and bottom more specifically )
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 2
Комментарии:
@Shane Pe helped me solve this by linking the screws that fit my switch perfectly! His advice can be found in a comment reply bellow! Thank you so much!
Assembly screws for switch on Ebay!
https://www.ebay.com/itm/For-Nintendo-Sw...
от
Thanks. But upon closer inspection it seems that there aren’t any Y000 screws. Those are the ones at the back of the switch.
от
Your suggested link or Shane Pe's? because his are the full assembly screws, every screw for the main console.
от
Shane Pe’s are only joy cons replacment screws. I am looking for some for the back of the switch. At the back without the joy cons there are 4 screws at the corners of the switch. I need those ones. The ones that require a Y000 screwdriver to take out.
от
Its not the Y000 but a set of screws that fit that back area. I read the description and found a picture clearly separating a set of console screws from joycon screws, please take a look at the listing again.
от
Показать 1 больше комментариев
Добавить комментарий
PC Laptop Batteries
An easy fix for a big power boost.
Купить сейчас
PC Laptop Batteries
Купить сейчас
2 Ответов
Выбранное решение
(The description from the seller even shows console+joycon screw separation)
Assembly screws for switch body on Ebay!
Был ли этот ответ полезен?
по рейтингу 1
Комментарии:
any comment on that shipper? did it arrive quick. also how many screws did you get, i cant tell if its just the joy con screws or the whole console
от
Наиболее полезный ответ
i believe its M1.4x2mm flathead black screw.
по рейтингу 2
Комментарии:
any link or image of this?
от
oh ok so this will work on the top and bottom on the back plate? I went ahead and accepted your answer but get back to me about that
от
I use my caliper to measure the screw and bought for myself. i will deliver results of fit when they arrive
от
Did the screws arive yet?
от
Показать 2 больше комментариев
Добавьте свой ответ
natclay96 будет вечно благодарен.
Просмотр статистики:
За 24 часа: 4
За 7 дней: 39
За 30 дней: 217
За всё время: 7,481
