Why is there no power to the iron. No indicator light on.
Whilst ironing the power light went off and iron stop working.
Это хороший вопрос?
Это хороший вопрос?
Many of the UK heating devices have a fuse within the plug. Carefully open the plug to gain access to the fuse. Here's an image of the plug assembly from the Morphy Richards Iron Teardown:
While not stated you'll see the far left & right connectors are also the fuse clips. With an Ohm or continuity tester you should see these are connected (with a fuse in place), If not you need a new fuse.
Был ли этот ответ полезен?
1. check the cord
2. there is a fuse in the steam iron press, get it replaced by service centre.
4. Thermostat is not working.
4. heating rod is damage.
Where can I get my iron seen to ? Rescaled it now won’t come on just keeps going off checked fuse new fuse in but still not coming on !
За последние 24часов: 14
За последние 7 дней: 101
За последние 30 дней: 381
За всё время: 26,941
3 Комментариев
I have lefty iron forgot to turn off just noticed but the iron is off and now won't work
из Susan Bracken
I’ve a steam iron generator it’s stopped workin the light doesn’t come on no heat nothing can u help?
из tina.kavanagh@hotmail.co.uk
My iron won’t switch on .. change the fuse
из roseann01
