Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80вопросов Показать все
I lost my dash lights 0n my Ranger?
My dash lights are all out except 3 lock/battery/air bags what is the cause
Это хороший вопрос?
Оценка 0
1 Комментарий
@ramtuf what exact years is this and what have you checked?
из
Добавить комментарий
1 ответ
Выбранное решение
If are you referring the the engine light and mil, brake light and abs lights this requires a new dash cluster this is a common problem with late 90s and early 2000s year fords . The only fix is a new instrumentation cluster . Try to get one from an aftermarket source as new ones from ford are not much better than the old one. This is one of the only things I tell customer to never buy from the dealer. I've replaced many in ford focuses and rangers . You can pick one up from Rockauto.com . Hope this helps
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
What exactly is an instrumentation cluster are you talking about the actual Dash bored
из
This is a 2007 Ranger
из
Добавьте свой ответ
Roger будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 968
