4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
1049вопросов Показать все
App calls on speaker, mic doesn't work
Hello everyone,
I just got my phone back after being repaired, updated ios 11 and I have a problem. During app calls whenever I set it on speaker, the other side can't hear me anymore. Just like if I pressed the mute button instead of the speaker. Normal phone calls have no such problems. Is there anyone, who could help me please? Thanks, Katka
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
What was the repair for - replacing the display assembly or replacing the charge port? If you had the display assembly repaired then the microphone on the front camera/proximity sensor flex assembly may have been damaged. Does the front camera and proximity sensor work okay? Or, if you had the charge port assembly replaced then perhaps the microphone on that flex assembly was damaged.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
@ittechrepair Yes, they have exchanged the display assembly. But the thing is, that when I call without using any app, then it's no problem using speaker, the mic works.. My front camera and proximity sensor work fine. I also talked about it with my friend and she said she's had the same problem for already 6 months and it appeared out of nowhere.
из
Добавьте свой ответ
Katka Hájíčková будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 290
