Отремонтируйте ваше устройство
Обучение ремонту
Магазин
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133вопросов Показать все
How much is it to fixed my screen
My screen is shattered how much would it cost to get it fixed
Это хороший вопрос?
Оценка 16
Комментарии:
How much is it to get my screen fixed on my zte max pro
из
My phone screen the glass part is shattered from the top left corner. How much would it cost to fix the screen?
из
How much is it to fix my screen zte max pro
из
how must do it cast to get my phone screen fix
из
How my will my zte phonecist to fix the screen
из
Показать 9 больше комментариев
Добавить комментарий
7 Ответов
Выбранное решение
If you wanted to repair the phone your self, the display assembly is around $30-35 USD.
It would likely be $20-$40 labor for a shop to do it.
https://www.ebay.com/sch/i.html?_from=R4...
Был ли этот ответ полезен?
Оценка 9
Комментарии:
My phone cracked up
из
It's easy to change the screen. Buy the screen and I'll change the screen for u for free.
из
Can you walk someone thru the repair via webchat?
из
How much is zte phone screen model Z982
из
Buy oem screen on eBay 28 bux, prolly 20 labor from "pro..." Or YouTube that ish yourself.
Оценка 3
Комментарии:
My phone drop in to water and the screen blank out
из
My whole screen is cracked on my ZTE blaze how much would it be to fix the screen will it be over 100 or under if I had to take it somewhere to get it fixed
Оценка 2
Комментарии:
my zte 2 blade max cell phone work charger and not work powern off/on you will fix what wrong what kind find my cell phone
из
They are many places where you can get a display dependent on your location. See the guide below.
ZTE ZMax Pro Display Assembly Replacement
Оценка 2
My ZTE zmaxx pro blade my screen is crack on the right hand side how much will it cost me
Оценка 1
Комментарии:
That's the same price, when you replace the screen, all the front panel of the phone come with it...
из
My zte is cracked on the the bottom left and right and top right and a little cracked in the middle how much would that be to fix the whole screen
Оценка 1
My zte is cracked all over and it want come back on PERIOD POOH!!!
Оценка 0
Добавьте свой ответ
Azea Brown будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 69
За всё время: 14,261
