iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
Это хороший вопрос?
Это хороший вопрос?
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
iPhone 6 Power Button Cable Assembly Replacement
iPhone 6 Front-Facing Camera and Sensor Cable Replacement
Продукт
$19.99
Продукт
$9.99
Инструкция
Сложность:
Сложно
1 - 2 hours
Инструкция
Сложность:
Модерировать
30 minutes - 1 hour
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 211
2 Комментариев
Does you volume/mute switch work?
из iMedic
Yes it works.
из eric collins
