How to change the battery
Это хороший вопрос?
Look on the back and give us the Axxx number and/or the EMC number so we know your exact machine and we can get you to the correct battery and installation guide.
Also I would suggest downloading, installing and running Coconut Battery so you know your batteries exact status instead of using Apples idiot lights.
Был ли этот ответ полезен?
Thanks Mr. Mayer.
This was a bad question as I thought I had seen the process before here in the forums but later with a little more research I found the process I had seen before was in the repair guides and that walked me through the complete process. Super easy :)
Thanks again.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 66
2 Комментариев
Unibody or retina? Which year?
из iMedic
Thanks iMedic,
This was a bad question as I thought I had seen the process before here in the forums but didn't find it. Then a little later with a little more research I found the process I had seen before was not in the forums but in the repair guides and that walked me through the complete process. Super easy :)
Thanks again.
из Surfalia
