Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218вопросов Показать все
How to charge battery without logic board
HI
I have faulty Logic board ,most likely charging circuit on iPad 4
Is there a way to charge battery without using logic board so called " jump start" , as i am almost sure charging circuit is not function and battery not being charge , can i just use usb charger ,old usb cable ,strip down wires and connect red and ground directly to battery ?
Also
Should ipad works without battery connected to logic board? just lighting cable connected directly to logic board viaDock Connector Charging Port Flex Cable and usb to mac computer, should itunes detect it this way or needs battery ?many thanks
Это хороший вопрос?
Оценка 1
1 Комментарий
Did you fix it? I have the same problem
из
Добавить комментарий
1 ответ
Выбранное решение
Unfortunately the iPad can not be switched on and boot successfully with no battery connected and charging cable plugged in.
To boot up the iPad you either need a working battery connected to the logic board or soldered wire to the battery connector hooked up to a DC bench adjustable power supply.
Battery can be charged by using some special adapter to connect to DC bench power supply or by just soldering wires to it and connecting it to the power supply, provided you charge at around 2A max and with a voltage of at least 3.7(min)-4.2V(max).
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
Great, thanks for helpful tip.really appreciated
So how about if i use iPad charger and lightining cable with exposed wires. Connecting red and ground ( cable end) to small battery board + and - . Would that works.thanks again
из
If this is being charged over USB to wall charger this won't be a good idea as it will pump 5v into the battery which will damage it. 4.2v is the maximum specified voltage for the battery.
из
Добавьте свой ответ
Krzysztof Szarkowski будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 1,869
