Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
1695вопросов Показать все
Is it possible to combine 2 WiFi Antenna
I was wondering if it would be possible to combine 2 separate WiFi Antennas so that I could possibly get a better connection
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi Patrick,
Unfortunately, there is only one Wi-Fi header on the PS4 motherboard, so you aren't able to plug in another antenna. You could try making a custom antenna for your PS4, like in this video. This could potentially give you better wireless connectivity. Good luck!
- Jasen
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Thanks. I was gonna tryin to splice two PS4 antennas together like iv done with speaker wire in the past but I think that video might work better then my idea
из
That is a possibility as well! However, I've found those externally mounted antennas work very well. I've made a couple for desktops with built in Wi-Fi, and they really do increase reception substantially.
из
Добавьте свой ответ
Patrick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 783
