My rca tablet keeps going to sleep.
Tablet goes to sleep every couple of seconds.
Это хороший вопрос?
Это хороший вопрос?
Hi
Check in Settings > Device > Display > Sleep to see what time period is set.
Был ли этот ответ полезен?
I've done that, and it still goes to sleep after five seconds.
doesnt work on mine either. sleeps every 10 seconds. sleep is set on never
i had the same problem. Sleep timer was set at never. I even went into the HDMI setting and put that timer on never. still it timed out every 10 seconds. i had the same thing happen a couple months ago on a different but same tablet and I did so much that i forgot what i did the first time. go figure. Now I am here to say that more than likely its a timer set in an app you have downloaded. which one? Who knows. Start with your cleaner app. I did it the easy way.. I factory reset it and chose not to forward any apps over from my other device. Boom!!! Now it works perfectly. Now I will go download a cleaner and see what happens...then move on from there. Im glad its over cause that can make a person really irritated. Good luck.
What if was like this the second you turned it on, right out of the box? I just have no idea what to do. Do you think that I should still do factory reset?
I'm having the same problem
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,235
3 Комментариев
Judi Lopez tell us exactly what it does and when it does this. Also, please verify that your tablet is a RCA RCT6378W2
из oldturkey03
rct6513w87
same problem
из Eric Dahlquist
I'm having the same issue too.
из Andrea Andr
