Why doesn't my ignition key unlock the drivers door on a 2002 LS430?
Ignition key unlocks all doors but the drivers door, You must lock and unlock the drivers door by inserting the key into the drivers door to lock or unlock just the drivers door.
Это хороший вопрос?
6 Комментариев
Does your Lexus have the door closer as well (Easy-Close Option)?
из oldturkey03
@oldturkey03 I didn't realize this was a system in these cars, this might be why it's so expensive from some retailers then!
из Jasen Friedle
@vehiclefreak409 I guess it's a build-in butler..... definitely snazzy!
из oldturkey03
@oldturkey03 I guess so! But it also introduces the issue of complexity and cost when it breaks xD
из Jasen Friedle
@vehiclefreak409 absolutely! You should see the way it is setup. Cam positioners, sensors, multiple motors and all. Okay, I get it! I pass and use valet service for my 2002 Ford F-150 with 250K miles ;-)
из oldturkey03
Показать 1 больше комментариев
