The Dell Venue 11 Pro is a flexible slate tablet built for business. It comes with many work-oriented features, including Windows 8.1, a removable battery, and a variety of docking solutions.
11вопросов Показать все
Tablet will no longer turn on
I have a Dell Venue 11 Pro 5130 that stopped powering on. It seems that it's completely dead. I have tried different reset options that were listed on Dell forums but they aren't working. I tested the charging cable and that works fine. I replaced the battery and that wasn't it, I also replaced the USB charge port board but that didn't work either. One of the last things I could try is to replace the mother board. Do you guys have any ideas on how to fix this before replacing the MB or do you think that's what will fix something like this.
Thanks
Это хороший вопрос?
Оценка 3
Добавить комментарий
1 ответ
Hi Thomas,
My First Question - How did you repair the Charging port on the board. Are you a technician. If yes Then Probably You need to check the Voltage with the help of Multi meter to see the power in the board. Then its a board level issue.
If you are not a techinican, I recommend Checking all the flex cable again and the Battery Connector to see whether they are inserted properly and Also the Charging port as well. Everything looks fine then probably you might have to see a Repair techinican who can fix it.
Regards,
Sahil
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Sahil,
I bought a replacement USB charging board and installed it. I am a somewhat experienced technician, I don't do this everyday but familiar with taking things apart and replacing other parts. I can check the voltage, can you give me some tips on how to properly do that?
Thanks
из
Добавьте свой ответ
Thomas Cacaj будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 19
За всё время: 1,954
