If anyone else is still wondering what are those for, then as Adam said, black L-shaped part is a holding piece for the screw which mounts vertical stand to the console.
Silver springy metal piece is connecting ground (together with a BD Drive cover and woobly metal sheet) from power supply to internal metal parts and among them, also circuit board of Blueray Disc Drive.
Forgetting to put it back in, can be the cause of Drive not ejecting or not taking disc's anymore, but I doubt it would make console dead like not turning on, UNLESS someone forgot also/(or just - in meaning - only) that metal sheet that sits on top of Power Supply Unit and PSU long screws wouldn't have enough connection with motherboard cover plate (dirt, rust) - that would likely cause console acting strangely. In extreme cases not turning on or powering down after few seconds.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
8 Комментариев
I had another peice fall out
из Josh Gawthorne
Me too its snap like the letter u how do I post the pic tho??
из Jamel Woods
Hi,
Really need some help please.
When replacing the silver cover that goes above the disc drive and fan I knocked a small spring off.
It was located at the top of the disc drive before this, but now it’s come free...... and I’m not sure how to replace it ! the PS4 keeps trying to eject discs and won’t take a new one.
Any advice would be very gratefully received.
Thanks.
из Martyn Eley
do you still have the spring
из Levi Amos
My ps4 slim disc drive arms are not moving,I think the spring has come off
из David Dimond
Показать 3 больше комментариев
