Pontiac G6 — среднеразмерный автомобиль, выпускавшийся компанией General Motors. Он был представлен в 2004 году как модель 2005 года на смену Pontiac Grand Am.
2007 Pontiac G6 Gauges go crazy or stop working. Car bucks and jumps
Out of the blue the gauges start going crazy or stop working all together. Car bucks and jumps. Dealer said it was a loose ground wire and it worked for about 2 months and then the same old thing. Only has 70,000 miles.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hmm. A bad ground connection usually causes the needle in a gauge cluster to fluctuate unnecessarily. It is possible your ground connection got a bit too corroded and is causing your problems. If you know where the ground wire was previously tightened, try cleaning up the oxidation around that connection and seeing if your problem goes away. If it does, hit that spot with spray paint to prevent further rusting. It is possible the location on your wiring harness that connects from the (-) on the battery to the frame is corroded or a part of the wiring harness insulation has become exposed.
Remember, a car battery can kill you. When working on a car wiring harness, make sure to remove the wires from the battery terminals and isolate the battery terminals with electrical tape. Sometimes it's a good idea to replace the battery terminals if they become too corroded / oxidized or deformed.
Good luck.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Kevin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 9
За последние 30 дней: 29
За все время: 4,070
