This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
247вопросов Показать все
My DS Lite screen edges are now starting to fade
My DS Lite screen hasn't been used for maybe 3 years because I lost the charger and I just recently bought one. Now, its fully charged but the screen (both the top and bottom) now has like weird stains and it makes the edges turn white when I turn it on (refer to attached photos for reference). Help. How do I fix it? DO I clean it? If not, where can I get it fixed? Where do I buy a new screen? Help!!
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Unfortunately there is no other fix than replacing both top and lower screens.
However, the parts you will need are fairly inexpensive and the repair processs should also be easy.
I have linked all the parts you will need for this repair and our iFixit guide on how to do it.
You will need: the Upper LCD, Lower LCDand the touch digitizer for the new lower LCD.
Here's the guide for the Lower LCD, this one's for the upper screen.
You will also need this special screwdriver to open it up.
Nintendo DS Lite Touchscreen Изображение
Инструкция
Nintendo DS Lite Touchscreen Replacement
Сложность:
Средняя
30 minutes - 1 hour
Nintendo DS Lite Upper LCD Изображение
Инструкция
Nintendo DS Lite Upper LCD Replacement
Сложность:
Сложно
2 - 3 hours
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Hunnis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 27
За последние 30 дней: 114
За всё время: 4,343
