2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
465вопросов Показать все
Changed screen and now have only white screen when turn on computer
I changed the display screen with new one, turned on and get a white screen? checked all connections, even plugged in broken screen and it still lit up on part of glass not cracked. any ideas?
Это хороший вопрос?
Оценка 1
2 Комментариев
What happened with the previous screen to need a replacement ?
из
Daughter dropped off desk and cracked the screen, ultimately had to send to Apple and was fixed
из
Добавить комментарий
3 Ответов
Выбранное решение
The original screen had a small crack after falling off a desk and the bottom half of the screen was not working. Ordered a replacement screen and the replacement screen was faulty.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
surely this is a software problem. Try starting up from an external USB device with a known good system on it. If it boots, run Disk Utilities from the external drive and see if that will do the trick.
Оценка 2
Maybe you have not connected all the wires. If it is not of this then you will need programming pairing which only Apple does, and because you replaced the screen yourself they may not do it because it is Apple .
Оценка -1
2 Комментариев:
Never heard of that before. There is no programming a screen.
из
I like to see some validation of this programming pairing. Could you give us a link?
из
Добавьте свой ответ
herrky будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 197
