Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
72вопросов Показать все
screen can't recognize my knuckle after screen replacement
I replaced my huawei p9 broken touch screen with a new one and since then, everything has been working normal except that it doesn't recognize my knuckle gestures anymore. It sees my knuckle as a finger touch instead. I have checked the gesture settings and everything is active. What can be the problem?
Это хороший вопрос?
Оценка 4
Добавить комментарий
1 ответ
It may be the sensitivity on the screen due to the new screen. Try using a different combo of gestures. Correct me if I’m wrong. I never had this phone but I replaced a screen on my otr phone and it’s sensitivity is SUPER high. You don’t have to even touch the screen to have it register the touch. Good luck
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
domijoeindaclub будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 965
